Modulefpreviousupnextcontents[BIG][Normal][small]
Next: 1.3 Changing the mesh structure Up: 1 Mesh manipulation Prev: 1.1 Geometric transformations Contents
1.2 Changing the finite element type
Module NOP2P1 converts a NOPO data structure containing P2 elements into a structure composed of P1 elements only. In practice, the module splits triangular P2 elements into 4 P1 triangles (the point coordinates on the edges are calculated at the center of these edges).
      SUBROUTINE NOP2P1(M,NFNOP1,NINOP1,NFNOP2,NINOP2)
C ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
C AIM : GEOMETRIC TRANSFORMATION OF A P2 D.S. NOPO INTO A P1 D.S. NOPO
where
An analogous module, NOQ2Q1 converts Q2 elements with 9 nodes to Q1 elements.
      SUBROUTINE NOQ2Q1(M,NFNOP1,NINOP1,NFNOP2,NINOP2)
C AIM : GEOMETRIC TRANSFORMATION OF A Q2 D.S. NOPO INTO A Q1 D.S. NOPO
C ---   (Q2 WITH 9 NODES ONLY)
Module NOTRP1 converts a NOPO data structure containing triangular elements with 7 nodes into a structure composed of P1 elements only. In practice, the module splits the initial triangles into 6 P1 triangles.
       SUBROUTINE NOTRP1(M,NFNOP1,NINOP1,NFNOP2,NINOP2)
C AIM : GEOMETRIC TRANSFORMATION OF A D.S. NOPO CONTAINING RUAS
C ---   TRIANGLES WITH 7 NODES INTO A P1 D.S. NOPO
where
