Modulefpreviousupnextcontents[BIG][Normal][small]
Next: 7 Internal programs Up: 6 Input management Prev: 6.2 Interaction subroutines Contents
6.3 Entering a position in the 3D space
To introduce a position into the 3D space, it is firstly necessary to indicate in which part of the user space we are interested. The following subroutine is used in this case:
Once the user space is specified, it is necessary to display several views (straight, front, bottom, perspective) of the context in which the position must be introduced, on the screen. The following subroutines are used for this purpose:
Once the context is displayed, it  is  possible to enter a  position  using 2 points entered successively on two distinct orthogonal views.
