Next: 7.8 Implementation aids
Up: 7 Internal programs
Prev: 7.6 Matrix and vector manipulations
Contents
Numerous sorting subroutines are proposed here. They differ in the type and number of input parameters. They all have "HEAP" in their names except BUBBLE. The *HEAP* subroutines correspond to sorts of O(log n), whereas BUBBLE is of O(n**2).
SUBROUTINE BUBBLE(TAB,N)
INTEGER N,TAB(N)
sorts TAB in order of increasing values (BUBBLE-SORT).
SUBROUTINE HEAP(CRITER, RECORD, N)
INTEGER N, RECORD(N)
REAL CRITER(N)
sorts the values of CRITER in increasing order. RECORD follows the reordering.
SUBROUTINE HEAP2I(CRITER, N)
INTEGER N
INTEGER CRITER(2, N)
Sorts the values of CRITER(1, *) in increasing order. CRITER(2, *) follows the reordering.
SUBROUTINE HEAP3I(CRITER, N)
INTEGER N
INTEGER CRITER(3, N)
sorts the values of CRITER(1, *) in increasing order. CRITER(2, *) and CRITER(3, *) follows the reordering.
SUBROUTINE HPD2I(CRITER, RECORD, N)
INTEGER N, RECORD(2, N)
DOUBLE PRECISION CRITER(N)
SUBROUTINE HEAPDI(CRITER, RECORD, N)
SUBROUTINE HEAPI(CRITER, N)
INTEGER N
INTEGER CRITER(N)
SUBROUTINE HEAPI2(CRITER, RECORD, N)
INTEGER CRITER(N)
SUBROUTINE HEPI2I(CRITER, RECORD, N)
INTEGER CRITER(N)
SUBROUTINE HEAPI3(CRITER, RECRD1, RECRD2, RECRD3, N)
INTEGER N
INTEGER RECRD1(N), RECRD2(N), RECRD3(N)
INTEGER CRITER(N)
sorts the values of CRITER in increasing order. RECRD* follows the reordering.
SUBROUTINE DHEAP(CRITER,RECORD,N)
INTEGER N,RECORD(N)
SUBROUTINE HPLX2I(CRITER, N)
INTEGER N
lexicographically sorts the values of CRITER(1, *) and CRITER(2, *) in increasing order.
SUBROUTINE HPLX2R(CRITER, RECORD, N)
INTEGER N
REAL CRITER(2, N)
INTEGER RECORD(N)
SUBROUTINE HPLXNI(CRITER, MM, N)
INTEGER N, MM
INTEGER CRITER(MM, N)
lexicographically sorts the values of CRITER(1, *), CRITER(2, *) ... CRITER(MM, *) in increasing order.
SUBROUTINE HPLXNR(CRITER, MM, N)
INTEGER N, MM
REAL CRITER(MM, N)
INTEGER FUNCTION IDICHO(CRIT, N, VAL)
INTEGER N
INTEGER CRIT(N), VAL
searches for value VAL in CRIT by dichotomy .
CRIT is assumed to be sorted in increasing order.
Input: CRIT, N, VAL
Output: IDICHO = Index in CRIT if VAL is found;
if VAL < CRIT(1);
N if VAL > CRIT(N).
The following relation holds:
VAL < CRIT(IDICHO(CRIT, N, VAL)+1)
INTEGER FUNCTION DICHO(CRIT, N, VAL)
INTEGER N
REAL CRIT(N), VAL
searches for value VAL in CRIT by dichotomy.
Input: CRIT, N, VAL
Output: DICHO = index in CRIT if VAL is found;
if VAL < CRIT(1);
N if VAL > CRIT(N).
VAL < CRIT(DICHO(CRIT, N, VAL)+1)
